I want to add one step from part B to part A without redrawing or converting the stair to the scatch based.
do you have any solution?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
.... magic ? ![]()
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Would you please send a video I tried more but it doesn't work properly. I want the below image
@Anonymous wrote:No. only I want to remove a stair from B and add it to A
I'm dizzy, @Anonymous. I see "A", "B" and "C" on both Stairs, with an arrow starting from the left "ABC" stair and pointing to the right "ABC" stair. This indicates to me that you want to make the right configuration like left configuation. The difference between the two is LANDING EXTENTS.
Please take a look your solution doesn't work and it needs many cleaning jobs.
@Anonymous wrote:The right image at section B has 5 steps but the left one has 6.
Oh. so you want different riser heights? That's assuming their run lengths are the same.
No, I removed one step from B and added to the A. The riser and length and total number are the same. The middle landing's level is changed (because of changing the outside's grading's level). see the screencast.
Why are you sketching the landing non-contiguous? Looks to me like you could resolve your issue by sketching your landing correctly. Revit is even warning you that there is an issue with it.
