Changing new "section" view visual style
r.itardnut
r.itardnut
How do i make it so my new sections are 1:20 / fine / consistent colours when i first create a section?
I know i can make a view template and assign that but cant i just change what is "automatically" created by revit?
Currently they are always created at 1:100 / coarse / hidden everytime i make one. I cant see it in options......
Thanks.
rxi.gg
You can create a type of section with a view template asociated. so before you draw the section line, select the section type do you want and the section view created after, will have that view template asociated.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
