Changing model using length & Drop down parameter
6 ANTWORTEN 6
Nachricht 1 von 7
721 Aufrufe, 6 Antworten
I have created more than 50 families in revit with length & drop down parameters. Now my model is changing according to length. But i want to change my model in both ways(Length & drop down tick box). So please give me a solution for this.
Beschriftungen (1)
6 ANTWORTEN 6
Nachricht 2 von 7
RobDraw
als Antwort auf: Anonymous
Edit the families and add the parameter.
Good luck!
Rob
Nachricht 3 von 7
Thanks Rob. I have done all this before but still it's not working
Nachricht 4 von 7
alan_eu
I don´t know how you pretend to change family dimensions with a yes/no parameter. I don´t think it would be an easy task :verwirrtes_Gesicht: If you really wanna do this, you could create some kind of if(tick value, true result, false result with all ticked possibilities). You will have a full-page formula, so write-it on notepad and bring it back.
ex. If (1193, Lenght_M*1193, if (1255, Lenght_M * 1255, if (1318, Lenght_M * 1318, etc.............)))
Why don´t you just create many types with the length dimensions?
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
Nachricht 5 von 7
martijn_pater
Why not just create the types which set the length (doesn't that do anything? You have a shared length parameter?) and the corresponding type parameter, or associating the length to the nested family lenght parameter in type properties... so, not sure if I understand what you're looking to do actually...
Nachricht 6 von 7
als Antwort auf: alan_eu
Thank you Alan
I have already done these but still i can't find the solution for this.
Nachricht 7 von 7
martijn_pater
...still unclear what you are looking to do. Perhaps share the family and elaborate.
