Changing materials for generic models
5 ANTWORTEN 5
Nachricht 1 von 6
sstattelman4GLLM
931 Aufrufe, 5 Antworten
I can't figure out how to create a new material for all the generic Rhino models I imported into Revit. Going back to rhino and reimporting with materials would have been the way to go, but that file is too messy now... I was hoping Revit would just allow me to change the material of selected elements, but it doesn't seem like it will be that easy.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: sstattelman4GLLM
Why? What's hard about it?  What's your process?
Nachricht 3 von 6
sstattelman4GLLM
als Antwort auf: barthbradley
I am trying to go and edit the type to add the material, but it won't let me edit the type of a generic model it seems.
Nachricht 4 von 6
I'm not following. Post your file so we can look at it.
Nachricht 5 von 6
sstattelman4GLLM
Wow... I just found out the answer, sort of.. So in the first image the generic model won't let you edit type, as it's greyed out. But if I change the view to 3D rendered it will let me edit type. However, it just changes all the generic model to whatever material is selected, so I'm still a little lost. I can post the file tonight, as I'm finishing up rendering as a sketch instead of using the textures. So I can respond later with the file if still needed.
Nachricht 6 von 6
Likely has nothing to do with the type of view, but how you select the component.
