I would like my foundation footings to be displayed with hidden 3/16" lines. I changed the object style and this works for elements that are within normal depth. See the footings on the right as they are the correct line style I specified.
The footings I am pointing to with red arrows are only visible by adjusted the view depth. How do I change the line style of these footings which are visible in the view depth area?
Also, is it possible to have the dashed lines appear through the concrete slab floor on the inside of the walls on the basement side? You can see they are only visible on the outside because the floor slab is covering them.
