Changing language in project broswer
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
2108 Aufrufe, 9 Antworten
Hi, anyone know how I can change the language in project browser ?
9 ANTWORTEN 9
Nachricht 2 von 10
RDAOU
als Antwort auf: Anonymous
@Anonymous
I believe That changes when you change or use a template...the English will be English; French would be French ....etc
hopefully you are starting a new project so there ain't much work to do (just start new and browser to a different one)
Nachricht 3 von 10
als Antwort auf: RDAOU
The thing is I have already finished my project. is there anyway I can transfer the work onto a new template ?
New with revit so not sure what to do now, though I can just change it at the end ...
Nachricht 4 von 10
semko_dm
HI!
I think, that this article can help you.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Tags (1)
Nachricht 5 von 10
RDAOU
@Anonymous
The only way to this is by using the right template...There isn't an easy way to it no (at least none that I know of)...you will have to do it manually and in steps.
There isn't an option which transfers all...ie:
  1. transfer model (Link and bind could help)
  2. tranfer standards
  3. transfer families, views and sheets
  4. ...etc
not hard but tidious (would be nice IDEA if they would allow to open a project in a different template)
what you can do if you are a subscriber...put a ticket to Autodesk and see if they Could do anything to help you out. I think they can do it fairly easy at their end
@semko_dm if you haven't tried it before; that changes the language of the menus only! NOT THE TEMPLATE
Sent from my iPhone
Nachricht 6 von 10
als Antwort auf: semko_dm
Thanks, but does not work
Nachricht 7 von 10
I will try contacting auto desk
edit: nvm not a subscriber
Nachricht 8 von 10
RDAOU
@Anonymous
If you would be willing to read up on it a bit and start migrating the model; I would gladly try to help you along the way if you miss anything.
PS: can tag a couple of helpful Autodesk Support staff who are regularly on the forum maybe they could do something or help you out as a student (if I may assume that you are one)...
@loboarch @Rafal.Gaweda @Judy_S
Nachricht 9 von 10
I will have a read on migrating later
got any link on it ?
Nachricht 10 von 10
Rafal.Gaweda
Hi
No other way than the one suggested by RDAOU - migrating model to new language template and changing \ translating "old texts" by your own
Rafal Gaweda
