Changing from Construction Template to Architectural Template
12 REPLIES 12
Message 1 of 13
21254 Views, 12 Replies
I received a revit file for a building that is in the construction template. I would like to change it to an architectural template. I tried transferring project standards to a new project, but it only transferred over wall templates/details etc and not the building itself. I also tried copy/paste into a new project, but there were a bunch of errors that popped up when I pasted and it wouldn't let me click the check mark to complete the paste. Thanks so much!!
12 REPLIES 12
Message 2 of 13
You can Transfer Project Standards from the Architectural Template to that file.  Why do you need to change it by the way?
Message 3 of 13
in reply to: ToanDN
Just tried that and it doesn't seem to have worked...I guess the main reason I'd like to change to architectural is because of the scaling/dimensioning. It's showing up as 1:100 scale and doesn't have any architectural options. This is a building I'm using for my Interior Design Thesis project, so I'm more familiar with the architectural template. Thanks for your help!
Message 4 of 13
Corsten.Au
Hi
Transferring project standards from one file to another only allows types of family, view templates  colour fill schemes, text styles etc ( long list )..
It doesn't transfer the project.
1. I would suggest you link " Construction based template " file to " Architectural based template " file.
and then Bind link..
This way you will get exactly what you need.. ( 3D elements ) and no 2D elements which anyways you
want to use Architectural family types, line types, graphics etc..
or
2. Just use Architectural based template file , with link model if you are not making any changes but
using to create sheet, views etc.
Cheers!
Corsten
Building Designer
Message 5 of 13
Do you want to work on metric or imperial units?
Message 6 of 13
in reply to: Corsten.Au
@Anonymous wrote:
Hi
or
Cheers!
These should work but the 1st option will destroy any Phasing configuration if Phases are used in the original model.  If there is only one Phase then it should be okay.
Message 7 of 13
That worked!! thanks so much!!
Message 8 of 13
@Anonymous
Mark @Corsten.Au's post as the solution, not mine 😉
Message 9 of 13
in reply to: ToanDN
Oops good catch, thanks!
Message 10 of 13
how do you exactly link the construction based template file to an architectural based template file via the bind link?
Message 11 of 13
Corsten.Au
Hi..
Revit Template file  *.rte
Revit Project file : *.rvt
1. Create a new Project using Construction Template . . Save as " Construction.rvt
2. Link that new Revit file   " Construction.rvt "  to any other Project " rvt "
Hope that helps..
Corsten
Building Designer
Message 12 of 13
Hi Ganesh,
I think we’re talking past each other. I’ll try to be more specific.
I’m doing a project for the extension of Copenhagen airport. I want to design the site layout with detailed logistic plans.
I got the contractual model from the consultant but I’ve been told that I have to convert it to an architectural model.
First of all I want to know why I can’t work with the structural file and second of all how can I convert it to an architectural model?
Thanks again
Best regards
Denise Kays
Message 13 of 13
Corsten.Au
to give a quick backround of Revit....
Revit used to come in different Packages.. like
Revit Architecture
Revit MEP
Revit Structure etc..
in recent changes, they implemented everything in one.. and those
Services are shown in " Discipline " now..
DisciplineDiscipline
now various consultants work in their respective discipline and using corresponding
template..
now.. considering Architectural Model ( Architects, Designer working ) they use
Architectural Discipline , and Consultants send their Revit Model for coordination where
you may link the Stcutural model and build Architectural around it.  and vice versa..
Structural guys will use Architectural model as a reference .. so that no once make
changes in each others model, field.
Its more of whos responsible for issuing drawings.. as an Architect you may not issue Structural , MEP, Electrical
drawings, and vice versa..
so that takes care of technical and probably legal and professional part...
in Revit terms you can merge any model and work...you can link structural model in Architectural file,
bind it and get all the elements live to make changes...but its all depends whether you are allowed or have authority
over it...
just get the scope of your work clarity and you are set....
hope that helps.
Cheers!
Corsten
Building Designer
Forma Design Contest
