Changing Family Parameter
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
993 Aufrufe, 11 Antworten
When I attempt to change more than one family parameter in the properties at a time it locks up.  If I change one parameter then hit apply it works, but if I select another parameter without hitting apply it locks the second parameter and reverts the other parameter to the previous entry.  See attach clip.
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: Anonymous
Somethings canceling something out. Can you post the family?
Nachricht 3 von 12
als Antwort auf: barthbradley
The issue does not show up on coworkers computer.  I have recently moved to a new computer in the last week.  I will load the family for you to look at though.  I am not sure if the issue isn't with the latest update to Revit.
Nachricht 4 von 12
The family works fine in the family editor it is just when loaded into a project that I have the issue.
Nachricht 5 von 12
As far as I can tell from a quick inspection is that the nested family's Cut Angle Left and Right don't need to be associated to Host Parameters.
...that seemed to correct, but I could be wrong. I want to verify for me?
Sorry. I see. Back to drawing board...
Nachricht 6 von 12
If you change the x brace height the angle needs to change for the cut.  That is why it is tied to the host family parameter angle.  I assume this family works fine for you just like it works fine on my coworkers install.  I untied the angle parameter and reloaded it in the project and I still have the same problem.  I can only change one value at a time.
Nachricht 7 von 12
@Anonymous: I can't break it in the project. It flexes fine for me.
Nachricht 8 von 12
Yes I think it is an issue with my install but I don't know how to fix it.  We reinstalled Revit today hoping it would fix the issue but it didn't.  Is there a place to post this for Autodesk support to look at?
Nachricht 9 von 12
Nachricht 10 von 12
cbcarch
Try loading it into a new Project--does it still cause the error?
If not, then it's something ( like a constraint) in your project where you have the problem.
Try the "reveal constraints" tool at the bottom of the screen.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 11 von 12
als Antwort auf: cbcarch
I contacted Cad Technologies Center and they had the solution for me.  The solution is to remove the add on for precast structures.  Once I uninstalled the add on all is working as it should.  I assume everyone whom my family worked for do not have that add on installed on there system. Thanks for the responses.
Nachricht 12 von 12
Weird. Post that information as the solution. Could help other.
