Changing duplicated views annotions simultaneously
3 ANTWORTEN 3
Nachricht 1 von 4
FalBaz
250 Aufrufe, 3 Antworten
I have duplicate with detailing views I want annotions to be changed simultaneously with the parent view, i'm using copy/paste method, is there any other practical method?
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: FalBaz
no other way just copy and paste. annotations, dimensions..etc are per view specific. thanks
Nachricht 3 von 4
RDAOU
@FalBaz
Only for annotations no...BUT you can use Duplicate as Dependent..this way everything you change in the parent will change in the dependent including yet not limited to Annotations, View Range, Scale, View Template, Overrides..etc
If you only want the Annotations to be synced you will have to stick to Copy to Clipboard from one and paste aligned in the other.
Nachricht 4 von 4
FalBaz
I'm using duplicated views to have more saperated view templates, duplicate as depndent is linked with the parent view templates
