Changing Dimension Text Value using Dynamo
suganesh_matrix_a540
Message 1 of 12
Hello everyone
Can anyone guide me on how to change the dimension text value for multiple dimensions at once? Please see the attached image below. I want to toggle between those options using Dynamo.
Replies (11)
Message 2 of 12
RPTHOMAS108
I'm not sure you'll find node that will do exactly that, likely you'll have to write a Python node that is using API methods such as:
Dimension.ValueOverride
or
DimensionSegment.ValueOverride if it is a multi segment dimension (using Dimension.NumberOfSegments to iterate Dimension.Segments).
It will likely set overridden or not depending on if you provide something or null to the ValueOverride property I expect.
As with the UI you'll have to provide a text value that isn't something that looks like a number or normal dimension value alone.
Message 3 of 12
Thank you for your reply.
I don't know how to use API methods.
Message 4 of 12
RPTHOMAS108
Ask the question on dynamo forum and perhaps someone will provide a Python code example, it is fairly easy to do. Alternatively become self taught via https://primer2.dynamobim.org/ etc.
However generally it is a bad workflow to replace dimension values with text.
Message 5 of 12
L.Maas
Here a concept.
LMaas_0-1691430299962.png\
LMaas_1-1691430326683.png.
You will have to find a way which dimensions to change
Dimension.SetValueOverride to change the value
Dimension.ValueOverride to ask what the valueoverride is
Louis
Please mention Revit version, especially when uploading Revit files.
Message 6 of 12
Thank you. Will do.
Its just in few locations i need them that way.
Message 7 of 12
Thank you for that concept script! Will try it out.
Message 8 of 12
How do it change it back to actual value of the dimension if its a text?
Message 9 of 12
L.Maas
Here two ways
Louis
Message 10 of 12
edson.maruyama
How can you do this if you want to override only a segment of a dimension. Let's say like you want to override the first and last segment.
I know Rhythm can isolate the segments, but I could not find a way to override their values.
Message 11 of 12
RLY_15
Proof of concept. Multi-segment dimensions are lists. The override node also accepts lists.
To only override the first/last segment, you can use something like Clockwork package's ReplaceItemAtIndex+ (allows multiple list replacements by indices)
EDIT: So I realized after posting that this still overrides the middle values, which is not good if those values change in the model (even if they're initially 'correct'). I'll look around to see if there's a package library that can isolate override state for each list item.
EDIT EDIT:
It's nulls. You put nulls in where you don't want to override the text.
Message 12 of 12
edson.maruyama
@RLY_15 it worked like a charm!
Used ReplaceByCondition to replace the values I wanted overriden, and to replace the others with null!
Thank you very much!
