when I import my model into navis for coordination it does not line up, is there some what to change my coordinates in revit so I can get these to line up?
Solved by ToanDN. Go to Solution.
right so I'm trying to bring in an architectural model in to navis where a structure model already exists and they don't lay over each other.
I recommend to fix the location of the models in Revit, and then export new .nwc files. If the user tries to "fix" this in Navisworks, that will need to be "fixed" every time there are new .nwc files to put together.
I stand corrected. I was thinking BIM 360 which can store model locations, Navis cannot.
@Anonymous
You should set up shared coordinate for Revit models before export to NWD or open in Navisworks.
