changing coordinates
6 REPLIES 6
796 Views, 6 Replies
when I import my model into navis for coordination it does not line up, is there some what to change my coordinates in revit so I can get these to line up?
6 REPLIES 6
It does not line up with what, other models?
in reply to: ToanDN
right so I'm trying to bring in an architectural model in to navis where a structure model already exists and they don't lay over each other.
Assuming you have linked the Structural model in your Architectural model,
have you setup a shared coordinates and published to the link(s)? If you
don't want to do that, just manually move your model in Navisworks to match
the others. I think Navisworks can save location of each model so it's not
a big deal.
Alfredo_Medina
I recommend to fix the location of the models in Revit, and then export new .nwc files. If the user tries to "fix" this in Navisworks, that will need to be "fixed" every time there are new .nwc files to put together.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
in reply to: Alfredo_Medina
@Alfredo_Medina
I stand corrected.  I was thinking BIM 360 which can store model locations, Navis cannot.
@Anonymous
You should set up shared coordinate for Revit models before export to NWD or open in Navisworks.
