Changing autodesk cloud families
1 ANTWORT 1
Nachricht 1 von 2
Luke.Gawthorp
95 Aufrufe, 1 Antwort
Hi everyone,
I wanted to get some thoughts on modifying cloud-based families in Revit. I often come across default families that don’t align with the standards or materials I need for a project.
For example, I’m currently working with a solvent-welded reduced tee junction. The default family is in ABS, but for my project, I need it to be HDPE and conform to BS standards. My instinct is to modify the family to suit my requirements, but I’m curious if this is a common practice among others.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Luke.Gawthorp
You can modify however you want then save it as another file because you cannot save over the cloud family (the ones via Insert Autodesk family button).
