Changing Annotation Line Thickness
satate22
satate22
When I try to change my annotation line thickness, nothing happens.
I was going to: Manage --- Object Styles --- Annotation --- Path of Travel --- (changing to 1/8" dashed solid black because I figured that was a thicker dashed line.
I'm trying to do Path of Travel lines in a fire safety plan, essentially the footprints of exit paths. So, my plan is halftoned and I just need these exit lines to display dashed, solid and thicker.
RDAOU
@satate22
It is a Line Style and deactivate Thin Lines display
satate22
That did make it thicker, but the dash didn't apply to it
RDAOU
@satate22
Path of Travel is a Line Style...you can change it under Manage >> Additional Settings > Line Styles
  • Alternatively: you can select all instances in view and override by element or by category or by a selection filter
satate22
Perfect, thank you!
