Changing a linked model's item properties
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
mfonooniSC9TN
1229 Aufrufe, 5 Antworten
Hi guys,
I linked a structural model to my Architectural model. I'm trying to change the "grid's" properties on the linked file. I want to make them smaller (from 1/8 to 1/16). Is there any way to change the properties of an item on a linked model like this to make it proper with our Architectural model?
(My Architectural Model scale is 1/16"=1'-0" but the grids on Structural are designed for 1/8"=1'-0" and they look huge for this specific view.)
Thanks and Keep safe!
Beschriftungen (3)
5 ANTWORTEN 5
Nachricht 2 von 6
syman2000
als Antwort auf: mfonooniSC9TN
Normally I would turn off the Structural Grid and only display their structural element. That way you have the control over the grid display and not rely on Structural model to dictate your view.
Nachricht 3 von 6
mfonooniSC9TN
als Antwort auf: syman2000
So is there a way to copy all their grid to my model so that I wouldn't do it again?
Nachricht 4 von 6
hmunsell
use the copy/monitor tool to copy the grids from structural and monitor them. If the structural model changed, you will be notified and be able to coordinate them.
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-604A097E-3C10-4D1A-B115-9BBB11B88416
Howard Munsell
Nachricht 5 von 6
syman2000
You can use copy/monitor. Select the structural grids
Copy MonitorCopy Monitor
Once it is copied over, you can swap it with Architectural Grids
Nachricht 6 von 6
_Vijay
@mfonooniSC9TN  You can edit or change the linked model elements or their property. as above replays, you can do as you needed.
