Changes not Saved - central model
2 ANTWORTEN 2
Nachricht 1 von 3
mairh_tsek
560 Aufrufe, 2 Antworten
I am working in my local file.. I sync the project with the central model and when I go to close the ptoject I have this message. [See attachment]
What does it means? The changes that I did in the model will not be sync with the central?
Also before I close the project I save it localy + sync.
I hope for a quick answer.
Thank you in advance!
2 ANTWORTEN 2
Nachricht 2 von 3
Sahay_R
als Antwort auf: mairh_tsek
Save and sync if Revit asks you for it. You can't go wrong.....
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 3
MostafaElashmawy
it means that the changes are synced with central but not saved localy.
check attached and check the highlighted box while syncing.
Mostafa Elashmawy
