I've created multiple floor plans that have the same / one shared associated level.
When I click on the level in an elevation view, it takes me to 1 of the 3 floor plans, but not the view that I want.
How can I change which view Revit prioritizes? I understand that you can't change the associated level of a view after it's been created.
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
The view that the level is opening is determined by which view was created first. That relationship is permanent unless that view is deleted and the relationship moves to the next plan view associated with the level. So practically we can't change that relationship. You can however select the level and right click > Find Referring Views to open a dialog on select the view you want from a list.
Steve Stafford
This is where a good naming convention comes in handy. Finding - and going to - a Referring Views that you want to go to.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-3CBE91F5-985D-412A-84F2-CDD712CFC553
