Change view to read "Not to Scale"
17 ANTWORTEN 17
GELÖST
Nachricht 1 von 18
vanderloo5
22859 Aufrufe, 17 Antworten
I'm using an inserted image from google as a detail and want the view scale to read "Not to Scale"
Is there an easy way to do this?
Tags (1)
17 ANTWORTEN 17
Nachricht 2 von 18
Alfredo_Medina
als Antwort auf: vanderloo5
Open the list of scales for the view. Select Custom... > Display name > type "NOT TO SCALE".
Tags (1)
Nachricht 3 von 18
chrisplyler
als Antwort auf: Alfredo_Medina
Nachricht 4 von 18
als Antwort auf: chrisplyler
Hi Guys,
My viewtitle doesn't goes back to the previous scale. It is not satisfied with "NOT TO SCALE". Is there a way I can edit the system family?
Nachricht 5 von 18
It appears that it doesn't work anymore. See the attached image.
Using Revit 2018 for this older job....
Nachricht 6 von 18
RobDraw
als Antwort auf: Anonymous
See your other post about the same issue.
Rob
Nachricht 7 von 18
Scale does not show for 3D views.
Nachricht 8 von 18
als Antwort auf: ToanDN
Ya I just figured out that was what my issue stands from. Thanks.
Nachricht 9 von 18
RobDraw
Good catch, @ToanDN.
Rob
Nachricht 10 von 18
mroble
als Antwort auf: RobDraw
I've had no problem creating a custom scale that was 1:1, but the Display name was "NTS"...
What I'm trying to do, and having a hard time doing is applying this custom scale to a Drafting View view template. So I don't have to do this for every one.
Am I missing something?
Even if I set it to Custom in the view template, apply, and OK my way back to my view, it doesn't do anything. I go back into my view template, and it's back to 12"=1'-0"
Nachricht 11 von 18
Sahay_R
als Antwort auf: mroble
Edit the View Title Family. Give the Scale label a visibility parameter. Place a piece of 'dumb' text (or an instance parameter driven text label) over the Scale label, give it visibility parameters. Create a type with the Scale label hidden and the text label visible. Not the most elegant solution, but it will work. Live happily ever after.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 12 von 18
mroble
als Antwort auf: Sahay_R
This doesn't seem like a means that'll place "NTS" in my titleblock though.
It works if I do the Custom and set a 1:1 scale with a display text of "NTS", but I can't apply this work to the template. No offense, but what you're describing seems like a work-around that'll not give me the carry-through to the titleblock. For that much work, I can just as easily make one Drafting View, do that NTS work, then relegate myself to NOT creating a Drafting View from scratch anymore, but "Duplicate with Detailing" over and over as needed. That "NTS" works holds up with that workflow. I just wanted to verify that I could or could not rely on the template to do this work.
Nachricht 13 von 18
Sahay_R
A solution was asked for, a solution was provided.
It's for you to pick and choose which one suits the required purpose.
Rina Sahay
Nachricht 14 von 18
mroble
@Sahay_R
I don't mean to offend at all.
But does your solution result in the "NTS" carrying through into the titleblock?
Nachricht 15 von 18
chrisplyler
One possible solution is just to create a separate title block with the Scale label removed and replaced with the text NTS. Then choose the title block / sheet that you want as is appropriate.
I personally don't understand why people want a scale listed in the title block anyway. There's one in each view title, which may all be different on a given sheet, so what good is the one in the title block?
Nachricht 16 von 18
mroble
@chrisplyler
"I personally don't understand why people want a scale listed in the title block anyway. There's one in each view title, which may all be different on a given sheet, so what good is the one in the title block?"
I tend to agree.. one place or the other, you know?
I think it boils down to whatever company standards are.
More often than not though, I've seen people omit having a View Title completely for the opposite reason...
You already have the title in the titleblock, and a scale in there. Those folks only use view titles with scales when you have several sections and/or enlarged plans due to several different scales being used on that sheet.
As for my situation, I'm finding the most seamless way to do it is to create the first drafting view, apply the template, make the NTS scale and stuff, then create more view by "duplicate with detailing", and that works like a charm.
I just wanted to get the template to handle it and not have to tell everyone that you need to, essentially, "save as" over and over making each drafting view. And even worst tell them to NOT create new.
I'm thinking someone (not knowing) goes and creates 15 views, all saying 12"=1'-0", I'd like to be able to grab all 15 in Project Browser and apply the template in one shot, boom fixed.
Instead, it's currently "Add Custom...... 1:1, .....Display "NTS", ok, now do this 14 more times....
Nachricht 17 von 18
ethannavah
HEY! TRIED DOING YOUR SOLUTION, BUT DOES'NT WORK BY ME. WHEN I SELECT "CUSTOM" FROM THE VIEW SCALE LIST, IT JUMPS RIGHT A WAY BACK TO A NUMBER SCALE.
PLS ADVISE
THANKS
ETHAN
Nachricht 18 von 18
Avneet_Kaur46FTA
als Antwort auf: ethannavah
Not from Properties, but by activating a view, do the same step as mentioned from this bottom scale. You will achieve the result.
