How do you change the thickness of already established split regions? Apologies if I am missing something really simple.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
If you need more control over the line thickness in your views, you may need to adjust the line weights in the Object Styles or the Visibility/Graphics settings for that specific category
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
I was wondering if the layer thickness can be adjusted after you have created the split regions. Larger scales takes care of any line weight issues.
Select the edge of the Layer and you'll see a Temp. Dimension that you can change.
