Hi;
Is there anyway to change the tex size of a tag by category in revit. Change the scale from 1:100 to 1:200 to place it on the revit sheet. want to reduce , but can't find it the edit option
Gelöst! Gehe zur Lösung
Gelöst von Toan_RLA. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Don't understand. Text is annotative. You mean you want the Tag to use a different Text size? You need to create another Tag or Tag Type with the Text Size you want - and then replace all via Select All and choosing a different Type from the Properties Selector.
@Djokaboris wrote:Hi;
You mean text size changed by scale? No, you cannot change the scale of a view and have the annotations resized. Annotation sizes are based on paper space (sheet) dimensions, i.e. 3mm text is 3mm at any scale when you print out.
- You need to create different tag family using small label size if you want to print 1:200 drawing at full scale, label will be very small
- You can split the 1:100 view and place each view on a separate sheet and use the "normal" sized tag
- You can print the 1:100 view with "normal" sized tag at 50% scale
