change the look in the view on my floor
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
845 Aufrufe, 7 Antworten
I can’t change the look in the view on my floor, the floor is set to be WOOD as in the photo
It is always color grey. In realistic or ray trace, or even rendering it keeps showing grey
What do I have to do?
7 ANTWORTEN 7
Nachricht 2 von 8
aRcHiTeCt.JM
als Antwort auf: Anonymous
… if the floor is always getting that grey halftone color
… it is usually – most probably that your floor is set to existing phase condition
… you need to change it to new construction phase to get the material showed
…. Could you upload your .rvt to take a look ?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 3 von 8
als Antwort auf: aRcHiTeCt.JM
Here is the simple file. I just deleted the rest
Where are the phases that you are talking about?
Nachricht 4 von 8
aRcHiTeCt.JM
…. hi @Anonymous
… based on yor model
… yes. You have set the floor to an existing phase
… just change it
…. Click on the floor
… choose phasing
… phase created
… and change existing for new construction
…. Then click outside the model
… done
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 5 von 8
thanks bro, this revit is so complicated.
Nachricht 6 von 8
If the floor is existing and you want to show its material correctly, change the view's phase status to Show Complete.
Nachricht 7 von 8
als Antwort auf: ToanDN
where? what can I do?
Nachricht 8 von 8
oh , I got it thanks
it was not an existing floor. but good to know
