Change revit Language
2 ANTWORTEN 2
Nachricht 1 von 3
mairh_tsek
654 Aufrufe, 2 Antworten
Hello all,
We want to change the language in Revit 2018 from English to French.
I already changed the 'language ENU' to 'language FRA' [
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2019/...
But after that  Revit crashes. Is there the possibility to have Revit license only in english?
Thank you in advance!
2 ANTWORTEN 2
Nachricht 2 von 3
Erense
als Antwort auf: mairh_tsek
Any luck when first removing the Revit.ini and letting it regenerate a new one when starting with the new shortcut.
I am using this method to switch between two languages since Revit 2017 when Structural detailing was still language dependent.
Basicly Revit is Revit and not language dependent. However it might be because some license show up as language version.
You can check if there is anything irregular in the About -> Revit 2018 information screen with the license information. (Don't share a printscreen from this)
Just tried switching to French without any problem.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Nachricht 3 von 3
You have to install with the language selected.   You can change this in the Autodesk Desktop App settings and then download/install again.
