Change Referring Views
1 ANTWORT 1
Nachricht 1 von 2
1134 Aufrufe, 1 Antwort
I created a sheet that has a 1/16 scale view and a callout at 1/4 scale. I was asked to add a 1/8 scale and change the 1/4 scale view to reference the 1/8 scale and the 1/8 scale to reference the 1/16 scale. If I try to copy the callout to the 1/8 view it creates a new callout. If I try and delete the callout anno off the 1/16 plan it tries to delete the callout view.  Is there a way to change the 1/4 referring view to show on the 1/8 view and change the anno on the 1/8 to refer to the 1/8.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
You may create a dummy callout and manually select the view you want to refer to.
