Change one stair step type, without changing everything in the model
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
uffe0441
918 Aufrufe, 3 Antworten
I'm trying to make different steps inside the house than the ones I used on the porch. But when i change it, it also changes all the other stairs.
3 ANTWORTEN 3
Nachricht 2 von 4
alan_eu
als Antwort auf: uffe0441
Hi @uffe0441
You have to click on the duplicate button before click on ok button, so you will create a new step type that will change only that one.
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
Nachricht 3 von 4
hmunsell
you need to duplicate your Stair type, duplicate you Run type, and set the new material.
https://autode.sk/3olD6TK
Howard Munsell
Nachricht 4 von 4
uffe0441
als Antwort auf: hmunsell
Thanks a lot, it worked perfectly.
