Change one levels floor plan without changing all of them
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
aadamsA2F2Z
2272 Aufrufe, 3 Antworten
I have a apartment complex I am working on where all the floor plans are different on each level. How do I make an update to one of them without it automatically switching all of them?
Best,
A very frustrated new Revit user :leicht_lächelndes_Gesicht:
3 ANTWORTEN 3
Nachricht 2 von 4
RobDraw
als Antwort auf: aadamsA2F2Z
Without more information, any answer would be a wild guess.
What are you editing? What have you tried so far? Pictures would help tremendously.
Rob
Nachricht 3 von 4
jvpantin2
Hi, @aadamsA2F2Z, the only thing you have to do is work only in the specific floor plan of the level you want to change. There is no reason for this to make changes in the other levles, unless you previously grouped  and make multiple copies or constrained elements among levels. Verify if your walls and rest of elements are constrainted within the levels you want to modify. I.g., if you modelled a  wall troughout all building levels, obviously if you move it will move in all floor plans; to prevent this behavior you must constraint from base level to top level within the desired level and above, and same to each level. If this won't works, please give more information in order to help you better.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
Nachricht 4 von 4
aadamsA2F2Z
als Antwort auf: jvpantin2
This helped, I believe I know what the issue is now! thank you so much
