Hi All,
Just wonder is there CHANGESPACE command in Revit? I drafted a detail on paper space, is there a way that I can transfer to details to model space without redrawing the detail?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I am not an expert here. However, i think it would have been of best interest for you to have written the details in a duplicated view "duplicate with detailing" of the plan and put that model with detail on the sheet. Hope this helps.
@Anonymous
No there is no such command in Revit. In Revit you have
If you would post a screenshot of what you have drafted and in which of the above views, then one might be able to tell you if it is transferable or what is the easiest way to recreate it in a different view if that is possible
@Anonymous wrote:
Hi All,
You mean you drafted on a sheet instead of a drafting view? No you can't "CHSPACE" in Revit. If it is not a lot if work then redraft it in a proper view (Drafting view, Legend). If it is a lot of work, you can export the sheet to DWG, import the DWG in a drafting or legend view, explode it the you will be able to continue to work on the detail if need be.
