Change Image for Material
Good aft. I want to change the image dispaleyd for a material as per attached. Once I go to Edit Image I can't make my way to upload my own image for it.
Any ideas  more than welcome! Thanks
stevecrotty
I am not sure of your problem and so may need more detail.
Do you mean you select the "edit image" item in the arrow pulldown and there is no place to edit the image there?
If so this is correct.
Click on the image name under the image in the dialog you show and it is a link to browse to a new image.
Let me know if this does not help.
Steve
