I loaded this Pile Type in Revit Project using Dynamo. But i want to change the Family Type based on the Pile No. I created using project parameters. Is there an easy way to change the family type without selecting each Pile. I tried the revit schedule to change but it only allows each pile so it is very time consuming. Any idea, add in or dynamo that could solve this problem easily. Thanks.
Select one pile > right click > select all elements in project > change to a different type.
Thanks but I think you missed the point. I want the Pile No. same as the Family Type. Example Pile No. is A-3, so my family type should be Pile: A-3
Why? Why not using Mark for Type No.?
Because there is a system that is designed by our company and it makes use of unique Global ID to update the pile model when you export to IFC. If you use only one Type of Family when exported to IFC it has the same Global ID thus the system does not work.
Why is the Global UniqueID based on Type and not Instance? Sounds like a fundamental flaw.
I think when you load a family with the same type in revit project when exported to IFC the GUID is the same, so the system does not work. I tried changing the Type of the Family and when exported it produces unique global id.
In the schedule,
you should be able to change the type in the schedule. you will get a warning message about changing all selected types, or something like that.
Howard Munsell
Thanks but I already did that. But I want to make it easier to change the family type according to Pile No. since these are thousand piles and its very time consuming if I would do it every single pile.
I don't which method did you generate the GUID in the IFC but the IfcGUID generated when exported from Revit to IFC is unique for every element.
I agree with others that it seems not the most efficient method, but here an example
You might need to add to the script. In case you have two columns with the same PileNo, you might start to run into errors. Script attached
Louis
Please mention Revit version, especially when uploading Revit files.
Maybe look into using the parameter IfcName (instance based) to control the Type/Names of elements in IFC's
Also the documentation of the Custom IFC exporter: IFC for Revit
