Change family thumbnail in properties box
21 ANTWORTEN 21
GELÖST
Nachricht 1 von 22
emmanuelbee
9331 Aufrufe, 21 Antworten
when you create a family and load it into a project, revit gives a default thumbnail of the family in the properties box, is there a way to change which view of the family is being shown in the thumbnail?
21 ANTWORTEN 21
Nachricht 2 von 22
als Antwort auf: emmanuelbee
Go to Save As and open Options
Nachricht 3 von 22
emmanuelbee
als Antwort auf: barthbradley
tried that it doesn't work
Nachricht 4 von 22
emmanuelbee
it changes the thumbnail but not in revit, the thumbnail will change if you place the file on your desktop etc, it will show the thumbnail that was saved, but in revit, in the properties area, it doesn't change the thumbnail there
Nachricht 5 von 22
You know, I go through this sometimes and it doesn't always refresh the thumbnail of a family already loaded in the Project.  Sometimes it does; sometimes it doesn't.  Try it in a fresh Project and I betcha it works like a charm.
...What family category is it?
Nachricht 6 von 22
emmanuelbee
its just a generic model
Nachricht 7 von 22
Corsten.Au
Check " Regenerate view "
PreviewPreviewRegenerateRegenerate
Corsten
Building Designer
Nachricht 8 von 22
emmanuelbee
als Antwort auf: Corsten.Au
I've already tried that, it doesn't work
Nachricht 9 von 22
XXalessio.amodioXX
I am having the same issue.
Did you find any solution so far?
Nachricht 10 von 22
emmanuelbee
als Antwort auf: XXalessio.amodioXX
No there is no official solution to fix this problem, its a bug in revit.
Nachricht 11 von 22
XXalessio.amodioXX
For some families, like column with corbels, I have solved the issue Joining the exstrusion, thus the it will recognized as a unique volume. Try it and let me know
Nachricht 12 von 22
JJRevitUser
Has there been any update on this from anybody at Autodesk? Maybe somebody asked during AD answer day
Nachricht 13 von 22
als Antwort auf: JJRevitUser
Rename the old version in the project and load in the new one...  Select all the old versions in the project and change to the new one.
Or
Do the above in your template and don't worry about existing projects if not too big of a deal.
Nachricht 14 von 22
JJRevitUser
als Antwort auf: Anonymous
Definitely, I am working in one of our templates right now building & adding schedulable families. But by my understanding of what @emmanuelbee seemed to be asking was that under the properties pallet when a family is selected & it shows the thumbnails for those types of families, the thumbnail for that family will be the same for every type of the same loaded family.
I was just seeing if an autodesk member or somebody knew about any updates on this topic since the last post but thank you for the reply!
Nachricht 15 von 22
JJRevitUser
On second reading I apologize as he was asking about just the one thumbnail. Now then I have a question if anybody would know it.
Is there currently a way to change the thumbnail for each type of a single family?
If not, why bother with the code that enables thumbnails for the types of a family to begin with.
Nachricht 16 von 22
Nope, it is one thumbnail per family.
Keep in mind, some families are messed up where the Front and Back are reversed in the thumbnail (Casework) in the Properties window but look correct in File Explorer.
Nachricht 17 von 22
JJRevitUser
That's unfortunate, maybe they will add that sometime. I mean the thumbnails are already coded in (R17), they just keep showing the same one for every type. Maybe easy, maybe not, I am not a coder but it would be a cool thing to see happen possibly. Thanks for the tip & reply!
Nachricht 18 von 22
dnenovMXKU9
This is actually quite pervasive and difficult to get rid of. You can regenerate the Thumbnail all you want, save, resave, rename, push in new projects, change and create new Family Types, purge ... it's still there. The family remembers that initial image somehow. Really, really strange.
Here is a bit of information that mentions the discrepancy between file thumbnail preview and Type selector preview:
https://graitec.co.uk/blog/entry/revit-thumbnail-orientation
It seems it's the View Cube that dictates the Properties Box View orientation but that's about it. The Type selector will always show an Isometric, Shaded view of your Family Type as set in the Family (instance parameters are taken into account). That's my understanding for the time being.
Nachricht 19 von 22
randy_lmn
I'm having the same issue.  Here is a great example of the thumbnail somehow reversing for furniture.  Revit 2018.3.  Doesn't matter what the thumbnail is.  Still does it for brand new families.
Nachricht 20 von 22
rsahayEAPZD
als Antwort auf: randy_lmn
The only thing that I have found that works - is to flip the geometry in the Family so that Front is Up instead. For longer lasting results - flip similarly in the Casework template, save as a family, then change the extension from RFA to RFT.
