Change dimensions on schedule for TBD
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
gabrielferna4
689 Aufrufe, 14 Antworten
Good morning, everyone.
I have a windows schedule, and we don't have the final measurement so we need to change the dimension for TBD.
I know there's not an easy way to do this on Revit, but I need a workaround.
Thanks!
14 ANTWORTEN 14
Nachricht 2 von 15
jay_colcombe
als Antwort auf: gabrielferna4
You cannot do this as the Width, Height, etc. are dimensional constraints and reporting parameter information.
You could grey out the text and add the Comments Parameter Field with TBC
or
You could create new dummy  Schedule based on this window Schedule and add dummy Text Parameters replicating the Width, Height, etc. where you can add in TBC and swap schedules on the sheet when the dimensions have been finalised.
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 15
gabrielferna4
Tried greying out the text with conditional formatting, but it only allows me to change background color and not text color. There's a way?
Nachricht 4 von 15
jay_colcombe
Simply create a new Text Style which is Grey in Colour and Apply it to the Schedule
Jay Colcombe
Nachricht 5 von 15
gabrielferna4
als Antwort auf: jay_colcombe
But how do I grey out only the instances with the TBD comment?
I'll change every cell doing that IIRC
Nachricht 6 von 15
jay_colcombe
You cannot edit individual Cells unfortunately
You could use conditional formatting to highlight TBC Cells but its not a full solution but you can apply it to more than one parameter so Window Name could be related to the "comments" Parameter's in that row"
Other than taking a screenshot of an excel sheet edited as needed and Imported into Revit in a drafting view and dropped on a sheet.
Jay Colcombe
Nachricht 7 von 15
Just hide the colume, add a new text calculated value parameter to the schedule and enter "TBD" in the formula box.
Nachricht 8 von 15
jay_colcombe
Its a pain to do but you only have to do it once but you can use the Same condition for All Parameters and if comments is TBC it applies a Colours to All cells that use the Same Condition
Jay Colcombe
Nachricht 9 von 15
syman2000
Only way to achieve this is use key schedule.
Create new parameters and set them to text and add to the key schedule
For the key schedule, you create a list what type of door sizes you want to display
Select the door and set them to key schedule
When you schedule, you should see value placed in the schedule
Nachricht 10 von 15
jay_colcombe
als Antwort auf: syman2000
If the door sizes change in the model as they’re yet TBD does the Key Schedule update automatically?
Jay Colcombe
Nachricht 11 von 15
syman2000
It doesn't. Key schedule is just another data that can be manipulated based on set conditions. Even if the door is 3'-0" in reality, the key schedule is just type in whatever value you like. Yes I would love to have Revit ability to report real value combine with text. However key schedule is the only way to achieve this for now but they are just a dummy value. Hopefully in the future those real world value can combine with text value.
Nachricht 12 von 15
jay_colcombe
Thank you for the reply!
This is my worry even when creating dummy parameters in standard Schedules as I suggested is that we are filling a model with information that could at any point be out of date and incorrect and issued (and don’t get me started on Door or Window Legends!!!)
Jay Colcombe
Nachricht 13 von 15
syman2000
I agree and hope Revit developers see the need to develop better schedule capability without resorting to work around.
Nachricht 14 von 15
gabrielferna4
I agree with both. I got a even more rudimentary solution for this: just put an opaque TBD over the schedule on sheet. That fills my boss's needs and the rest of the schedule works as intended. I don't like it, but I can't keep losing time on this.
Thank both of you for your answers!
Nachricht 15 von 15
BDMackey
Would having a 0 value work, if so this can be done intelligently.
Add a Project Parameter to the door category that is a Yes/No value (instance based probably mine is called TBD)
In the schedule add that field and the width field
Do a calculated value with a formula if(TBD, 0', Width)
Hide the Width column and use the calculated value, when TBD is checked for the window it reads 0 uncheck it and actual width is displayed.  Sometimes explaining a new intelligent way is acceptable when the company has less liability.
