how can change the color of this drafiting view?
If I go to "Line Styles" there aren't pink.
There possibility to change the layer as in Autocad and then put the color I want?
Answer if you can with pics, please.
Thank's
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
In Visibility Graphics (VV/VG shortcut) for the view, not the object styles. That, or with your view template.
Other option is you could use a selection view filter, ie. select all lines --> save selection --> go to visibility graphics --> filters add --> scroll to bottom/select named selection --> override lines color in filter.
ah, imported CAD is under the "imported categories tab". Same way select your drawing --> override lines.
Ah, then you've (partially) exploded the CAD import. Then these layers will go under Lines as I said in first reply. Click on the + before lines (orange marker in previous post for individual layer overrides) and scroll down and you will find those. Click --> override --> select line color.
@martijn_pater It's ok, thank's.
But to put several color in the view I have to edit the .cad file with different layer?
I can't do this on Revit, right?
If you import/link the CAD file you will find the .dwg layers under the imported categories tab. Click the + which has the drawing name and you will find the cad layers as they are set in your autocad /cad software. You can overwrite those seperately.
In case you explode the cad drawing in the view. Then these layers/lines move to model category lines in the project. Click the + before Lines and scroll down and you should find them there. You can override them there seperately, same way.
Try to make a test cad drawing with a few layers/colors/lineweights and see what happens with all these options.
