Hello all,
I am fairly new to revit.
I have uploaded several 3d models (not an Revit model) in my design. But is showing in its original colors. Is there a way to change this so the 3d model looks consistent?
Gelöst! Gehe zur Lösung
Gelöst von alan.johnson7YLND. Gehe zur Lösung
If for example it was a 3D dwg when loading in you can set colour to black and white
As for files already in you model, if you select the linked file and right click, override graphics in view - by element
Then change the projection lines colour to black and apply
If you are importing OBJ, Collada or glTF you can change the material settings, and therefore get the color adjusted. See the video tutorial in this page.
