Hi, I need to have three same house with different levels at a project in one file. After copying the file I need to change all floors and stairs base and top level to new one. Is there any trick to do it quickly? Thanks for help
There are just three houses and I thought that linking would take more time.
Hi..
Consider the number of levels you will have for one house
total 2 or 3 at-least ( Ground, Level 1, Roof, or Ceiling etc )
3 houses makes it 3 x 3 = 9 levels
handling so many levels, and you might have just one Ground floor plan
to show all those houses.. one Deli-ma would be where to create that floor plan
and using which levels..
Also while modelling you will have to make sure you are using correct levels,
connecting to correct levels, offset etc..
Better to Link 3 houses to one master file .
Master file can have site plan, floor plans etc..
Cheers!
no trick to do it quickly
1 model for each building can be a cleaner approach
linked into a campus model for coordination and sheets set up
Level 1A, Level 2A, Level 3A - Model A
Level 1B, Level 2B, Level 3B - Model B
Level 1C. Level 2C, Level 3C - Model C
Level 1A = 0'-0"
Level 1B = 3'-0"
Level 1C = 5'-0" etc.etc.
