Change appearance of Step Treads and Risers in Realistic View
13 ANTWORTEN 13
Nachricht 1 von 14
rkernPBQSM
399 Aufrufe, 13 Antworten
I have been trying to change the appearance of the threads and risers of my steps, but have been unsuccessful in the Realistic view.  I can see that the change takes place in a 3d view but from a top down view in "Visual Style: Realistic with Edges" it displays transparent.   I would like the steps highlighted below in blue, to show with the ceramic tile like the 3d view...
2022-01-11 18_36_26-Autodesk Revit 2018.3 - [Floor Plan_ Level 1 Title Floor Details - N5668 2018-1.png
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: rkernPBQSM
Looks like someone put a Masking Region and Detail Linework over them in the View. Can you select and hide the MR?
Post the file.
Nachricht 3 von 14
It is easier to use a 3D top view.
Nachricht 4 von 14
I think I'm a little confused. Are you trying to change these Symbolic Representations?  You can't apply Material to them.  They are 2D elements.  Hide them in Realistic View.  That should resolve.
Nachricht 5 von 14
rkernPBQSM
als Antwort auf: barthbradley
I would like to add a material to the tread and riser and have that show in "Visual Style: Realistic with Edges".2022-01-11 19_19_34-Autodesk Revit 2018.3 - [Floor Plan_ Level 1 Title Floor Details - N5668 2018-1..png
Nachricht 6 von 14
Stairs are shown as graphic symbol on plan view.  If you want to show them with true materials, create a realistic 3d top view, isolate the stair, and place it on top of the floor plan view on sheet.
Nachricht 7 von 14
rkernPBQSM
als Antwort auf: ToanDN
Ok, I see what you are saying, just appears like a bit of work to isolate the parts needed.
Nachricht 8 von 14
Yes, I understand. Hide the Masking Region in the View (the white part). The Treads and Risers will then show the Material you've already assigned to them.  They're just covered by the Masking Region right now.
Masking Region on:
Masking Region off:
Nachricht 9 von 14
rkernPBQSM
I am unable to find any masking region.  I am not aware of creating any Masking Region.  I think the issue is in Realistic View because the stairs are a symbol.
Nachricht 10 von 14
rkernPBQSM
I "extended" the floor under the steps and used that to show the tile.  Not 100% accurate but shows correct in 2d view.  2022-01-11 19_42_01-Autodesk Revit 2018.3 - [Floor Plan_ Level 1 Title Floor Details - N5668 2018-1..png
Nachricht 11 von 14
I told you exactly what the issue is.  Masking Region.  Post your file. I'll find the booger.
Nachricht 12 von 14
rkernPBQSM
Was working to send the file and I think I understand what you mean by a mask.  In the Visibility/Graphics Overrides -> Stairs -> Transparency I set it to 0 and then the material that I applied appeared in the 2D Realistic view...
2022-01-11 19_58_13-Visibility_Graphic Overrides for Floor Plan_ Level 1 Title Floor Details.png
Thanks, this appears to work like one would expect.  I did not realize that the 2 symbol of the stairs was 100% transparent, no wonder the material would never show.
Nachricht 13 von 14
That setting would affect EVERY Stair in the View.  Only a couple of Stairs were affected in your Screenshot.  Are you sure there isn't an Override by Element applied?  To check, select Stair, right-click and select Override Graphics in View: By Element.
Nachricht 14 von 14
...nevermind. I see now you only had 2 stairs in the view.  The rest of it was flooring - that just looks a lot like treads.
