Chainage Markings in Plan View
13 ANTWORTEN 13
Nachricht 1 von 14
Bynger
609 Aufrufe, 13 Antworten
Hi. I'm trying to figure out how to do chainage markings along the centerline of a winding road in plan view.
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: Bynger
Is the centerline already placed? If so, by what method?
Nachricht 3 von 14
Bynger
als Antwort auf: barthbradley
I traced over a satellite image using detail lines.
Nachricht 4 von 14
So, you just want to identify the end points graphically?
Nachricht 5 von 14
Use Model lines or Railing.  Better yet, create in place mass, draw spline and divide it with 10 meter increment.
Nachricht 6 von 14
Bynger
No. Something more like a measurement every 10 meters along the line e.g. 0+000, 0+010, 0+020, 0+030... Previously I figured out how to do it by using the array tool to duplicate points along a relatively straight line and then using the dimension tool and changing the string type from continuous to ordinate. I feel like there should be an easier way to do this and the method I mentioned does not work as well on a line with many curves in terms of displaying the measurements along the curved line.
Nachricht 7 von 14
Bynger
als Antwort auf: ToanDN
How will these work better than detail lines?
Nachricht 8 von 14
Bynger
Yes your image is similar to what I am doing but how would you place measurements at each point using the dimension tool and not text?
What I have in my image is a mixture of ordinate dimensions and text. It would be tedious to do this in my latest project so I wondered if there was an easier way.
Nachricht 9 von 14
Easier way? From Satellite imagery?
Out of curiosity, what's the purpose/value of doing this?  I mean, you're essentially including Civil information on your Plans that is not coming directly from any Civil Planning.  Seems odd to me.
Nachricht 10 von 14
Bynger
An easier way of measuring along a line with many curves and having the measurements align to the curve and go from 0 to whatever is my end distance is at intervals of 10. The purpose is just to have a rough idea of distances along the line for reference, so for example if I needed something done between 0+050 and 0+090 this would be used as a guide to get to the exact area on the road.
Nachricht 11 von 14
You can turn on Show Node Number for the divided path so you can know roughly where a node is at what distance from start.
Nachricht 12 von 14
Bynger
I tried this but when I come out of the edit in place menu the nodes display but the node number disappears.
Nachricht 13 von 14
Yes you need to be in the edit mode to see the numbering.  You maybe able to use Dynamo to bring the node number to a tag but you will need to ask the for it in the DynamoBIM.org forum.
Nachricht 14 von 14
Bynger
Ok. I will look into this. Thank you both for your help so far and if you think of any other ways to do this please let me know.
