Certified Instructor in Revit Architecture
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
2760 Aufrufe, 2 Antworten
I applied for ACI back in January.
Eventually I received a reply from a testing center in Dubai named VINSYS whom stated that the ACI program was on hold.
As I tried to make contact again today, VINSYS replied that the program is still on hold and under review. This has been dragging for 4 months now...!!!
Can someone verify these claims please???????
2 ANTWORTEN 2
Nachricht 2 von 3
esk0r
als Antwort auf: Anonymous
Jalal,
Not sure about that particular center in Dubai, but I have been waiting for almost two years for the ACI in Revit to be reviewed, since I applied back in 2014.
I was told pretty much the same thing.
Interestingly enough, I have seen people in LinkedIn proudly displaying freshly obtained ACI certificates this year (middle east).
I wonder if they are actually legit...
Autodesk?
Rene Pellicer Garcia
Nachricht 3 von 3
als Antwort auf: esk0r
The ACI Program was recently restarted and is available only via the Autodesk Instructor Development Portal, https://aex.peakcdi.com.
The ACI Certification just recently started issuing badges. The program beta started in June of 2016 and the public announcements were made to the ATC community at AU2016.
My company built and manages the Instructor Development Portal, and we execute the ACI-Program from that platform, but the program details are determined by Autodesk. Our technical content is used as part of the ACI requirement. The Instructor Development Platform is built on our global PEAK network.  PEAK is a content and curriculum aggregation platform that was purpose built to support the Instructor Led Training environment. Our Learning Browser technology brings the PEAK and IDP Learning Experiences right inside of AutoCAD, Inventor, and Revit.
If you are an instructor at an ATC or AAP, you are eligible to register now. Please contact idp.support@peakcdi.com. You will need to provide your Instructor ID, Site ID, ORG ID, and some other information.
If you would like to see how you can use the PEAK platform for use in class, please contact me directly, or fill out a request for a 7 day trial here.
Good luck!
Ron Myers
