My central model is in it's infancy. I'm creating an 18 story building and I'm beginning from existing CAD files. I've linked 18 CAD files and placed them at their corresponding levels with the intention of tracing over them and eventually unlinking them. After this I created a separate sheet model to create my master set of sheets. The problem begins when I link the 18 story model into the sheet model. Within the 3d view I'm expecting to see all the CAD floors, but I see none.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
So, your Linking an RVT containing CAD into another RVT and then another RVT?
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-F8929030-3D77-4F7B-A01F-3C88C600466E
What is the reason for creating a "sheet model"?
CAD link to 3d will not show up by default. So you have to manually set the link to custom and go to import category and turn on the DWG link.
18 stories with 18 Levels/Plan Views? I would suggest this approach (highlighted). FWIW.
I'm doing this because I'm building the model a piece or floor at a time. I plan on tracing the model using the CAD links. This could take several years. Once a model floor is complete, I'll remove the CAD link. Also, I have about 3000 CAD drawings I have to convert and these drawings (sheets) have all the as-built information I'll need to import and format. The general idea is to separate the building model from the sheet models to keep the file sizes down.
