Hi, everyone.
We are working with a central file when we work with the team.
A central file may experience fatal errors. A central file cannot be synchronized somtimes.
As far as I know, the problem in the picture above appears when two or more people synchronize.
But, our teams were not synchronized and opened anyone.
Anyway, I detached this file and save the new central file, in order that for solved this problem. But it couldn't save for same name that original file. Like above picture..
If I save for different name, it's okay. Why are this problem?
Maybe, I think this reason is server(network for team) error or link rvt.
This file works in team network (not local network), and linked many link files (about 10)... I don't know the exact cause, but I think so.
I want to know the solution. If it's another cause, I'd like to know the cause.
I'm sorry if English is a strange.
Gelöst! Gehe zur Lösung
Gelöst von Simon_Weel. Gehe zur Lösung
Gelöst von M_Meshal. Gehe zur Lösung
I don't think it's possible because other project team members also use it. As expected, it's a server problem.
Is there any other solution? Thank you.
That's weird. Is the file read-only? Or maybe opened by someone else?
No, It's not read-only, and no one was opening the file. Come to think of it, the explanation was a little lacking, but non-central files can be saved under the same name. If I centralize, I can't save it.
That's a problem. It means someone or something is locking the file. Could you post a screenshot showing what happens if you try to save the file as a central model?
Of course, but that's the end of the picture I posted above.
The other window didn't pop up.
Just tried it to make sure. I create a new file and save it. Then I switch on Worksets and save the file in the same location and the same name as a Central file. And Revit doesn't display any warning whatsoever that I'm about to overwrite an existing file.
In your case, as I said earlier, it looks like the existing file is held open / locked when you try to save as a central file. And I wonder what that could be. On a Windows server, you can use Computer Management to get an overview of opened files, so if possible, check that out.
I also wonder if you can save as a central file to a different folder?
If I save a completely unrelated new file with the same name, it also couldn't be. The second you say, shows up like that even when everyone turns off the computer. Usually, it can be saved again after a couple of days, but I don't know why it doesn't work on the day.
It's possible to save it to the other folder you last say. But I want to save it to the same name, same folder, if possible, because I have to change all the other links.
In any case, it is inconvenient that the central file cannot be synchronized periodically, it goes wrong, and even if it is restored, it cannot be saved under the same name.
Please let me know if you know any other reasons or plans.
Thank you.
Like I said - you have to figure out what's keeping the file locked. If it's on a Windows Server, use Computer Management:
You need Admin permission to run it.
You can also try another trick. Close all Revit files. Make a copy of the affected file (just in case). Rename the affected file on the server to something like xyz.rvt. Open xyz.rvt and save it as a Central file using the original name.
