Hello Everyone,
Is there any way to automatically center a view cadre around an object in Revit?
Best,
Mahan
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Not quite. You can do this:
- Stretch the view crop to closely matching the element
- Select the view crop, use Size Crop tool on ribbon and enter Width and Height dimensions and the crop will resize evenly
@mahanmotamedi1991 wrote:Hello Everyone,
Unless you prefer doing it manually...Yes there is a way to automate that using Dynamo...
Editing Crop regions is one of the most commonly asked questions on dynamobim, Dynamo FB groups, LinkedIN and a few other communities. Simply google the following key words and it is guaranteed that you will find at least 10 working graphs you can copy and use
