How do i make a celings legend little wider and longer celings legend.
i am using now via Annotate>Component>Legend component.
This is small,but u can change the length not the height.
I tried also to change the scale .nothing helps.
Please can someone help me?
Sounds like you want a Plan View, not a section view. Does the ceiling surface have a pattern? If so, maybe a Filled Region will do. If that does not work for you , you'll need to create a family that you use to represent the ceiling in a Legend. Of course, you would apply your ceiling material to that Family.
When you place a Ceiling type in a Legend view you can ONLY show the section, not Plan/RCP. You will have to yse an alternate method to present the ceiling such as: a Filled Region, a Generic Model with the same material, etc..
Exactly. Thanks a lot for ur reply.
Can u explain little bit further in detail? please
Instead of using a legend, have you considered using a schedule of ceiling types with a column for an image that represents the pattern of the ceiling?
Do i have to do in Legend?
I tried it, celings material or pattern did not come to the filled region.
You don't have to. Despite shortcoming, Legends have their own advantage that you can place a single Legend view on multiple sheets.
You need to create a new Filled region type and assign the Fill pattern (that is used for the ceiling surface material) to it. Duplicate the Filled Region type to create new ones if you have more than one ceiling types.
