I'm working on a ceiling plan and without realizing I had done anything my ceilings appear to be shaded. I'm working on the hidden line view. My visibility and graphics don't have a ceiling override, nor is there one under Override Graphics in View. I don't believe that I selected anything to shade it. I have an old version that I can work from but I would rather not have to redo any work. Any suggestions?
Gelöst! Gehe zur Lösung
Gelöst von chrisplyler. Gehe zur Lösung
Did you change the ceiling material? Is is under a previous Phase? Is the view in Hidden or Shaded visual style?
What's the surface pattern of the ceiling material? Could it be a coloured solid fill?
I'm guessing either:
1. The material of your ceiling has a surface pattern that makes it look shaded, or...
2. You've got shadows turned on.
