Ceiling Plan
26 ANTWORTEN 26
Nachricht 1 von 27
1138 Aufrufe, 26 Antworten
Ceiling Plan
Hi, I am using Revit 2017 and created a three-story structure.  I applied a 2 x 2 ACT ceiling but cannot see it.  I cannot even select it within the ceiling plan view.  I can see it in 3D view and select it there.  Any help would be greatly appreciated.  I am very new to Revit.
26 ANTWORTEN 26
Nachricht 2 von 27
sg.kalidass
als Antwort auf: Anonymous
Kindly Share the Pics..
Use Wire frame mode to see
Nachricht 3 von 27
sg.kalidass
In Which View do u want to see?
For Wt purpose ?
Nachricht 4 von 27
sg.kalidass
als Antwort auf: sg.kalidass
And One thing This Forum For only Revit Live users ..If U have Any Other Questions Post it On Revit Forum ..
Nachricht 5 von 27
It's likely view range related. You're ceiling is outside the range.
Nachricht 6 von 27
als Antwort auf: barthbradley
Thank you.  How do I fix that then?
Nachricht 7 von 27
Look under the instance properties for the view and open up "View Range". Chick "show" at bottom for further clarification. Keep in mind, it's kind of reverse of what you might think -- you're looking up, not down, in a ceiling plan view.
Nachricht 8 von 27
see attached - it might be worth having a quick look at the help / tutorials for 'view range'.....
Nachricht 9 von 27
no mate - THIS is revit architecture forum..... not live
Nachricht 10 von 27
Hi, my view range is grayed out.  I cannot select it at all.
Nachricht 11 von 27
I can't even select different views at the bottom (i.e.:  realistic, etc.)
Nachricht 12 von 27
Sounds like you have a template attached to view.
...under view properties, look for View Template and set to None.
...If you are getting a little confused, it might be easier to just create brand new RCP view with the OOTB template settings. Go to View Tab: Plan Views: Reflected Ceiling Plans: uncheck "Do not duplicate existing views": and then pick the Level you want to make a Ceiling Plan from.  Then you can delete the incorrect view altogether and start afresh with the new one.
Nachricht 13 von 27
There is a View template assigned to the view. Edit the template and edit View range, or uncheck View range box in the template then you can edit it for the view.
Nachricht 14 von 27
als Antwort auf: ToanDN
I was definitely getting confused so I went ahead and tried to create a new one.  Still nothing is showing up.
The room I am trying to apply the ceiling to is the one on the far right with the circles within it.  I have no idea how I was able to get a ceiling detail and lighting within it but I did.
There are no areas on my first floor that is showing the RCP at all.  I can see it in 3D but that is it.
Nachricht 15 von 27
Can you cut a section and post a screen shot so we can see where the ceiling is at?
Nachricht 16 von 27
I did add attachments.  Did they not show up for you all?  If not I can do a screen shot of it.
Nachricht 17 von 27
Nachricht 18 von 27
I can see your ceiling view screenshots.  I am asking for a section screenshot, cutting through the ceiling and show the levels.
Nachricht 19 von 27
Does this help?  The ACT is highlighted in blue.
Nachricht 20 von 27
change your view range
