Hello all, I have been working on a single level building. The floor plan is completed now, so I wanted to move on to the RCP. When I click on Level 1 under Ceiling Plans, the Level 1 floor plan does not show up. I get a blank screen only. I checked ALL in view and visibility settings. What should I do?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
No, nothing at all. In all my other drawings the floor plan was there on its own right away. I really have no idea why this is happening.
What did you model in the floor plan view? Is there anything sticking up high enough to be captured within the view range of the RCP?
I had a 2D cad drawing which I imported to revit. I draw the walls and all the other things according to that, but I had to move some walls though. The imported cad drawing did show up on the level 1 ceiling plan, but it does not have all modifications I had to do along the way, so I cannot use it for the RCP. Level 1 is 12' high. How do I check the view range of the RCP?
All the walls are 12'. The 3D image looks really great. I just wanted to do the ceiling quickly. I tried all those recommendations I have received, but unfortunately did not help. Plus, I have been messing with the settings so much by now that some of my walls disappeared and when I try to redraw them I get this message: "None of the created elements are visible in Floor Plan: Level 1 View. ...".
I don't know what to do. It is just a big mess now.
Do not create the ceiling in an RCP view. Create it in a Floor Plan on the Level it belongs to, and then Change it's Offset parameter up to the appropriate height.
OMG! It was the Phase! I set it to Project Completion and everything appeared. Thank you for all the help.
Hey i'm having the same problem. How did you switch to project completion?
