Ceiling missing?
Ceiling missing?
rmaynard
Ceiling missing?
rmaynard
Another stupid question:
The ceiling doesn't seem to show in either the 1st or 2nd story under the ceilings levels (if that is the correct term).  I wanted to place the lights, switches, and receptacles.  I the floor plans, the switches and receptacles weren't a problem, When I placed can lights, they appeared but not in the ceiling.  I went to the 3D view and found them in the floor of the second level.  I would be simpler in the ceiling level.  Suggestions?
Post your file.
rmaynard
Nothing attached @rmaynard.
Hey, check out my suggestions at this thread where the OP is experiencing a similar problem as you.
https://forums.autodesk.com/t5/revit-architecture-forum/can-t-see-my-ceiling-or-3d-view/td-p/9783163
