Ceiling Joist Penetrating Roof
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
BigPicture045
999 Aufrufe, 3 Antworten
Notice how the ceiling rafters are coming through the roof of this model:
Typically these ceiling joist would be cut in the field to fit. The corners would be cut off at the end. The red line designates approximately where they would be cut off at:
Can a ceiling system be modified this way?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: BigPicture045
Draw a ref plane where the red line is and use ot to cut the joists.
Nachricht 3 von 4
BigPicture045
als Antwort auf: ToanDN
@ToanDN    What tool does the cutting?
Nachricht 4 von 4
Sorry I was thinking structural columns attached to the ref plane.  For beams use Opening by Face tool.
But to model it correctly, you would need to add sloped roof joists and they can join with the horizontal beams for a clean cut.
