Ceiling Hosted Void Family not cutting Roof
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
shaun_harris
1645 Aufrufe, 4 Antworten
We have a few families with this problem and not entirely sure how to easily fix this.  We have a void in the family to cut out the ceiling and that part works great.  The problem we run into is that the family doesn't cut into the roof stacked directly on top of it.  The ceiling and roof are joined.  I've tried having the family cut out the roof on an individual basis to no avail.  We've gotten around this issue in past projects by just leaving it until everything is pinned in place.  Then have to go back and host the element on the roof and edit the ceiling footprint to the same cutout.  Any help or easier ways to get around this is appreciated.Annotation 2020-07-29 112311.jpgAnnotation 2020-07-29 112327.jpg
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: shaun_harris
Convert it to face based family so it can cut any type of host.
Nachricht 3 von 5
shaun_harris
als Antwort auf: ToanDN
Good idea.  This screenshot is a face based family test.  That won't cut through the roof either.
Nachricht 4 von 5
2 ways:
- in the family, create a void in the family but do not cut the solid with it, set the family to Cut with Void when loaded, and use Cut geometry to cut the ceiling then repeat to cut the roof
- in the family, create two voids, one cut the solid, the other not, set the family to Cut with Void when loaded, place it on the ceiling and it will cut the ceiling, then use Cut geometry to cut the roof
Nachricht 5 von 5
So to clarify, the Family contains an unattached Void and "Cuts with Void when Loaded" is checked, and when you place an instance Family in the Project, you are using Cut Geometry to cut the Roof with the Family's unattached Void. Is that right?
This?
See "Cutting with voids in families when loaded":
https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revi...
