Ceiling hosted lights not attaching to ceiling
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
4808 Aufrufe, 10 Antworten
Hi
I am placing a ceiling hosted light in my ceiling plan for some reason its coming in above my ceiling (see attached pic)
when I chose pick new host it shows its being hosted to the ceiling but in reality its not.
Please help
I checked the family and the host is in the correct place.
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Anonymous
Post your family so that we can check it.  Otherwise we will just be guessing.
Nachricht 3 von 11
See Attached family its the out of the box from Revit 2020
Nachricht 4 von 11
Are you trying to place it in a Ceiling View?  Or 3D View?
Just to clarify: Open the Family, select the "Light Source Definition" Ref. Plane shown in above screenshot, and UNCHECK the box next to "Origin".
Nachricht 5 von 11
RobDraw
That's a face based family that can host to any surface. It looks like it isn't hosted to anything in the image. You need to place it while in a RCP view and make sure "Place on Face" is selected.
Rob
Nachricht 6 von 11
Just to explain what is going on: the family has two "Origin" Ref. Planes.  It's a mistake.
Nachricht 7 von 11
als Antwort auf: barthbradley
How do I change that?
Nachricht 8 von 11
Save and Reload the Family into the Project and place it in Ceiling View or 3D View.
Nachricht 9 von 11
is your ceiling view Wireframe or Hidden?
Nachricht 10 von 11
wendymichener
I opened the family of the pendent light that is not hosting correctly (it hosts but at the wrong elevation and won't move) and I could not find any box called origin to uncheck.  The Ref. level is in the family and there is a place where it calls out 8'-0" as the placement above the Ref level, but nothing about Origin.
Nachricht 11 von 11
wendymichener
I read down the thread, went back to the drawing at the top, made the image larger and found the proper level and the origin box.   It is fixed, thanks
