Hi All,
We are receiving IFC files (exported from Revit) from the architect and the ceiling levels/heights are coming in 50mm and 30mm lower in some areas when the IFC file is linked into Revit. The IFC file is fine when appended into Navisworks and the NWC export of the same Revit file is fine when brought into Navisworks also.
I have asked the architect to install the IFC exporter for Revit and tested some of the additional export settings but the same issues occur.
The issue appears to occur on the linking of the IFC file to Revit or the method of conversion from Revit which is causing 2 different scenarios of the file depending on which programme it is viewed in.
We are working in Autodesk 2016 for the project.
Has anyone come across this issue before? Any help is appreciated.
Thanks.
