Ceiling grid not showing up when exporting to AUTOCAD
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
joemcninch
3822 Aufrufe, 8 Antworten
Hello -
I am at a bit of a loss.
I have a project where I am trying to export RCPs for coordination with consultants who are using CAD.  Everything appears fine in my Revit model but when you export the view to CAD and open it, there is no ceiling grid information.  I have tried to verify layers and such but everything seems to be turned on and visible.  I have tried saving it in different year formats, visibility graphics, surface pattern modifications, and on and on;  nothing seems to matter.  I am sure I am overlooking something simple.  Any suggestions?
I am using Revit 2016 and Autocad Architecture 2014.
Thanks.
8 ANTWORTEN 8
Nachricht 2 von 9
joemcninch
als Antwort auf: joemcninch
If it helps, here are a couple screenshots of the files I am working with.  I am not sure that my company's policies will allow me to post files.
Nachricht 3 von 9
joemcninch
I seem to have narrowed it down to a graphic display issue that is only happening with this particular plan.  If I set it to wireframe and export, the grid shows up fine (along with a ton of other stuff).  It doesn't change the result of my export when I duplicate the view (with or without detailing); the ceiling grid is still missing.
If I export the other floors, they work fine.  None of the RCPs are using a view template.
Nachricht 4 von 9
If you create a new RCP view, will it export with the ceiling grid?  Can you cut a section thru the building and point out which one is the level you are having trouble?
Nachricht 5 von 9
joemcninch
als Antwort auf: ToanDN
Yes.  If I create a new RCP plan of the same floor, set the view range to same parameters and export it, all the ceiling information comes through.  I may just have to start copying and pasting the information from one view to a new one.  The plan I am trying to export is fully developed.
The ceilings I am attempting to export exist in section.
Nachricht 6 von 9
chrisplyler
Maybe just try a Duplicate w/ detailing view and test it.
Nachricht 7 von 9
joemcninch
als Antwort auf: chrisplyler
I tried that as well.  It appears that this view has become corrupted or something.
I will just have the project team create a new RCP and try copying and pasting the information into the new view and go from there.
Nachricht 8 von 9
Interesting. Are you on subscription? Send it to Autodesk, they might be able to see what is going on if that is your diagnosis.
Have you audited the file?
Nachricht 9 von 9
joemcninch
als Antwort auf: Anonymous
The file had been audited and did not change the outcome.  I will look into sending the file to autodesk for their take on the situation.
Thanks.
