Ceiling Grid Export IFC
2 ANTWORTEN 2
Nachricht 1 von 3
abu.dawoodWSWLP
507 Aufrufe, 2 Antworten
Hi all,
I have an architectural model (modelled in Revit 2021) which has been exported to IFC. However when the IFC model is imported into revit by a different team, the grid layout on the ceiling changes to what is originally modelled. Is this an issue with the exporter? or is there a setting I need to apply to ensure the grid remains unchanged?
Any help will be much appreciated.
Kindest regards,
Abu
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: abu.dawoodWSWLP
ACT?  Exports to IFC fine for me.  Check your Export Settings. Does it say IFCCovering under Ceilings: Surface Pattern.
Nachricht 3 von 3
abu.dawoodWSWLP
als Antwort auf: barthbradley
Hi @barthbradley
I have checked the ifc export settings and it is set to IFCcovering. The grids are exporting to ifc - however the issue is that the grid setting out changes so it doesnt match the original grid setting out.
Kindest regards,
Abu
